Old 05-04-2010, 03:13 AM
undy's Avatar
undy undy is offline
Rusty, now that I've reinforced the pedals mount pad there's no reason to reinvent the wheel. The Speedway setup wouldn't work well with my tunnel configuration.
Chas, the Lonestar has a fiberglass tunnel and firewall so modifications like that are very problematic. I've looked at every way possible to put a bell crank system in replacing the cable system. Without MAJOR work and the possibility of it looking cobbled up it's just not readily do-able.
I've ordered a longer cable so I don't have to go up and over the valve cover. The radius a bit gentler too. I also went with a woven stainless exterior on the cable for heat resistance and esthetics. I talked with Lokar tech and came up with this pedal. it's much stiffer and has a stronger base over the current pedal.
It's all due here tomorrow from Mr. Jegs.
Too many toys?? never!
