Old 05-06-2010, 03:21 AM
Ant Ant is offline
Default Ride height with 17 inch wheels
Boxhead,
Your car looks good! A question on your exhaust is the outlet 3" and what diameter is the muffler.
I had the wheel alignment done today, took it for a good drive and feels great.
I ended up setting the rear at 1 1/4 neg camber, 1mm toe out.
Front at 1 neg camber, 5 1/2 deg Caster and 1 mm toe in.
I wanted to get closer to 1 deg rear but with the car so low (now the rear lower arm is effectively longer) this was the most positive I could get out of the rear Camber setting.
So Aussie, when I eventually hit you up for tubular rear arms (will also get the FFR front uppers) I might need to get either the lower arm shorter or the upper arm longer.
A J. Newton
The 1960's rocked!
