Old 05-10-2010, 09:32 AM
SHTMDWN PA's Avatar
SHTMDWN PA SHTMDWN PA is offline
Cobra Make, Engine: EM with Ford 427 Side oiler
Default Should I go with Webbers?
I always learn so much here. I could use some advice from the experts.
I have been thinking about putting a set of Webbers on my Everett Morrison and any suggestions would be appreciated (where to get a set up, IDF’s or IDA’s). It is primarily a street car. Today it has a Holley 750 with a turkey pan on an Edelbrock 427 intake.
The engine is:
An original Ford 427 Side Oiler
Stroked using a SCJ crank that is internally balanced
Bore is .005 over original – no sleeves
JE pistons with LR Rods
Crower cam PN 16332 degreed at 105 deg CL
Intake duration 300 deg lift .577
Exhaust duration 310 deg lift .591
Edelbrock aluminum heads PN 6007
76cc chamber
2.09” intake 1.66” exhaust
Dove roller rockers with end stand
Header with the standard 4 into 1 sidepipe
Trans is a Ford big in big out toploader
Jag 3:31 power lock rear
Thanks guys.
