Old 05-18-2010, 04:14 AM
Rob. Smith Rob. Smith is offline
Stiffy, I thought about the heat and fading issues but the need for good lighting overrode that. I'm not having any external windows for security reasons and I didn't want the place the be dim and dark. I went for a tinted sheeting so hopefully that will cut down on some of the heat and UV.
I spoke to a couple of insulation suppliers and they reckon it's OK to use batts with a colorbond shed as long as you have a layer of foil between the batt and the steel. That shields them from the condensation.
I've seen some 'slide back' shades on wire tracks that concertina when opened. I don't know where I saw them but they were pretty simple. Maybe you could fit them to pull down when you aren't in the shed.
