Old 05-25-2010, 09:48 AM
Default Running spax on the front only
Learjockey1 frame #428. QA1 shocks are in the front end only. Running the 4 spax shocks in the rearend. Front springs are over 400+ now. Road racing and auto cross need high spring rates. I leave the rearend soft with the stock ERA setup of springs and shocks.
been running the Appleton rack for 10 years. works great. You will need a cooler GM pump, dual pulley for the crank shaft and make some lines. 5" pulley on the pump. simple setup. Cooler is bolted to bottom of radiator support on bottom of car. ERA modified the frame for the rack. You will need to setup the bump steering after replacing the rack.
