Old 05-26-2010, 08:55 PM
ccx1984 ccx1984 is offline
Cobra Make, Engine: 1981 CONTEMPORY COBRA, 351C
Default bending tubing with heat
if you pack the tubing with clean dry sand and plug both ends the tubing won't collapse while you heat and bend it around a form. if the tubing is 1/16" wall a peice of 5/8" round welded in both ends should work, it has to be packed very tight. i just made hinges for my car using 5/8" stainless tubing and bent them around a much smaller radius.
