Old 05-27-2010, 09:04 AM
blykins blykins is offline
Here's a 347 deal that we can do....
*Fully machined production block
*Block clearanced for longer stroke
*ARP main studs
*Scat 9000 series crankshaft (28oz external balance)
*Scat forged I-beam rods
*Probe forged pistons (flat top or dish to match application)
*Clevite main/rod bearings
*Total Seal piston rings
*Felpro rear main seal
*New cam thrust plate
*ARP cam retainer bolts
*Comp Cams hydraulic roller camshaft
*Ford Racing timing chain set
*ARP camshaft bolt
*Professional Products harmonic balancer
*ARP balancer bolt
*RAM billet steel 28oz flywheel
*Rotating assembly balanced
*Camshaft degreed
*Block painted, freeze plugs/galley plugs installed
*Assembly pictures provided along with build data (bearing clearances, degree specs, etc)
$3349
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
