Thread: Need Brake Help
Old 05-29-2010, 12:45 PM
jbcobra67 jbcobra67 is offline
Cobra Make, Engine: Hunter - 427
Default Need Brake Help
I'm totaly lost. I have the very same setup as JerryW on this site. New master cylinder that has been bench bled. Also put it on the car and hooked up the bench bleeder and fluid moves fine. My problem is I can't get fluid to the calipers. I've had it at the calipers before, but still had a soft pedal. So I bled the master again. The more I do the worse it gets. This one thing is keeping me from the first drive. Please make suggestion, I'm open to anything. Next step is to take it to the mechanic shop. I have struggled with this for more that a month now.
What type of master cylinder did you guys with manual brakes use, I think I'm going to switch.
Thanks
