Actually,
It is basically the same size as Cpteddie's, well...about the same size that it takes to completely cover the Hi-rize manifold (Aluminum) with a Carter/Holley and the LONG type COBRA air cleaner..
I ran out of "cloth/mat" yesterday so I had to sand it all down, just roughing it up and then added three more coats of thick mat so the mold can be repeatedly used. When I get ready to pop the mold off the original hood (shown in red) I'll take some more pictures and see what we end up with!
All the excess glass gets cut off and edges smoothed down. Let the entire mould sit for a day or two then I will check that it hasn't tweaked anywhere and if not then it is ready to make the first scoop for use!
Anybody want/need a larger scoop? Send me your hood, the $200.00 please and I will install the first one with no charge for labor or return shipping. I'll take a full set of pictures so the next guy will be able to do it himself. Good? Bad? Indifferent!?
By the way it is just over 1/4" higher than the "Cobra" Air cleaner is and is about 1 1/2"s wider on both sides for engine movement. When I pop the mould I'll get the full measurements. This should fit the Hi-Preformace ) Plastic "Hartman" Intake box as well as the Cobra R Manifold!
