Old 06-08-2010, 07:09 AM
jhv48 jhv48 is offline
I think I may have found the tool to unscrew the brass fitting at the block.
I bought a 7/16ths 12 point closed end wrench and cut a groove in the side of the head so that it would fit over the teflon tube and then slide onto the brass fitting.
Then, slowly, I could remove/install the fitting without removing the fuel pump.
Jim
