Thread: Need Brake Help
Old 06-08-2010, 05:04 PM
PNJSNAK's Avatar
PNJSNAK PNJSNAK is offline
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Before you move the mount on the trans, try to get a bit more travel out of the piston in the master cylinder. The clutch pedal should be attached to a threaded rod going into the M/C. I had the same problem and screwed around with the slave stroke, then tried to get a bit more stroke out of the M/C. Problem solved, the clutch works so smoothly, don't know why I ever had a cable in it before.
Jim
OhioCobraClub.com
