Old 06-11-2010, 10:20 AM
DAVID GAGNARD's Avatar
Originally Posted by CSXDreamer View Post
After building a 427W with original front sump oil pan, I filled with 5 quarts of oil, figuring that should be the minimum for an American V8. When I checked the dipstick, it showed a one quart overfill. Now, I'm trying to decide if the dipstick and tube are incorrect for this engine. Or, has the stroker crank with a .67" longer throw and larger diameter counterweights displaced a quart of oil making for the higher reading. The dipstick has a chromed handle, which to me means that it was a replacement. Replacement for what engine? I guess what I need to know is the length of the tube from the block and the distance of the distick "full" mark from the haft at the outside end.
Your oil capacity is determined by the oil pan size and the size of your oil filter, nothing else, cubic inches doesn't matter....oil filter size can be from 1 quart for a PH8A to 1.5 quarts for the larger racing filters to 1/2 quart for the shorter filters.....
Over the years Ford has made a number of front sump pans depending on what vehicle they were going to go into,(car/truck/4x4) and the oil capacity could be anywhere from 5 quarts to 7.5 quarts......that's why with an unknown pan, I always fill it with water to see what the capacity is if I'm not 100% sure of it's original capacity....
You need to determine what the capacity of your pan and filter is and put that much oil in the motor, run it a few minutes and shut it down, mark your dipstick using that level as full.......
You would have to put at least 10 quarts in a stock pan for the oil level to hit the crankshaft!!!!!!!!!
If your running a remote filter and/or oil cooler than you have to add that it as well.........
David
DAVID GAGNARD
