Old 06-11-2010, 01:54 PM
CSXDreamer CSXDreamer is offline
David,
Did you measure the volume for the "sump" part of the pan? I would think that you wouldn't want the volume all the way to the mating surface with the block. That would put the oil somewhat over the centerline of the main bearings, which are in the same plane as the bottom of the block and top of the oil pan. I realize that one now has to add more oil for the filter and remote lines. Thanks for responding.
