Thread: Hydraulic jack
Old 06-12-2010, 10:50 AM
cdnus cdnus is offline
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Originally Posted by ng8264723 View Post
My lift seems to have high lift arms. I wonder if I should follow your advice Craig. So you have 4 separate blocks you drive on? I was thing of a lone piece that iI could drive on. Maybe a 2X12X10? That should fit the wheel base of my Cougar as well. It seems I have this problem with a lot of my cars. My 03 Cobra is knida low to
Yes I have 4 blocks.
It would seem to me if you used 1 long piece,that would defeat your purpose as you would still have inadequate clearance on the sides for your arms.
With my setup almost the entire side of the car is open, the front is raised 4in. & the rear is 2in.
If you need more than that to fit your arms under, just add more levels.
NOTE: be careful on the rear, too much height & you will bottom out when the front goes over. (I knew you would figure that out, just threw it in for luck)
Craig
