Old 06-18-2010, 06:22 PM
Ralphy's Avatar
Ralphy Ralphy is offline
Originally Posted by CobraEd View Post
Because the coating prevents the piston from absorbing the heat from the combustion chamber.
Ed that seems the only answer. Even though the engine parts run cooler, the combustion chamber runs hotter.
As far as the dry lube, it sure would make nice insurance in case of oil starvation.
Bobcat, they also didn't put an engine under a hood on a 95 degree day then drive for an hour and get measurements.
Didn't Smokey Y attempt to build a motor without a cooling system?
