Old 06-19-2010, 02:37 AM
victor's Avatar
victor victor is offline
Cobra Make, Engine: DRB "Rough as Guts"
Originally Posted by WKB View Post
I don't know if this will help. The check list that I recieved from Ray states "CRASH PAD FITTED TO DASH – PADDED HI-DENSITY FOAM."
Warren
Any dangerous or sharp projections must be removed. These include edges that are exposed as a result of cutting and removal of body sections. All edges that vehicle occupants may contact must have a radius of not less than 5mm and a minimum thickness of 5mm of high density energy absorbing foam or similar material bonded to the surface and suitably trimmed.
Hope this helps...Found in Regs
XBorderMexican
