Old 06-20-2010, 09:29 AM
dlotz dlotz is offline
Default RE: more info
Originally Posted by FWB View Post
IMO....no, when you remove the hose\line going to the canister is there blow by coming out, can you feel positive pressure at the line? is there really excess blowby or are you getting too much oil up top? what rockers, what engine, how are you oiling the rockers?
fred
ps, i'm assuming an FE engine
Fred
Yes it's an FE, a 1965 sideoiler and I am using Erson rockers in the MR heads.
Can't get in there to check the pressure at the line but the clear hose I am using (from the block plate on the intake to the oil vapor canister) is discolored telling me I have something going through there. I also see vapor coming out of the upper driver side line (the line coming out the top of vapor canister and going back to the trans/differential).
I also see some vapor and oil traveling out the canister and going back to the oil pan as designed, but not a lot. I see more water condensation in this line, but then again I am not on the road yet to allow the road draft tube assist with this either.
What is conserning me the most is the smoke I am getting sometimes when I start up (even after I just ran it minutes ago) and the oil I found around the spark plug threads when I checked the plugs.
I idle at right around 80lbs, shift around 100 and peg it when I really get into it.
