Old 06-22-2010, 12:17 AM
D-CEL D-CEL is offline
Cobra Make, Engine: SPF 239
For me there are some problems with the McLeod system.
The main problem is that you must disconnect the hydraulic line to remove the transmission. Requiring refilling and bleeding of the system every time the trans is removed.
Second, is the difficulty in set-up. You will need to measure the distance from the trans mounting face to the clutch fingers before you purchase or order your throw out bearing, Their are different length pistons to make correct engagement.Hooking up and bleeding is a major pain in the arse! They can and will leak.
I have one, I have put them in a couple cars, But I wont recommend them. Too much of a hassle
Jason
