My set up is similar to yours I have the improved Mcleod HTOB. Yes it took time to set up, yes they need to be bled properly, yes you need a correct pedal stop. If I had to do it again, I would go the route many Superformance 460 set ups use. Late 80's Ford 460 Truck Bell housing with external slave and an old fashioned fork, my clearance is very tight I would have to modify the slave mount on the bell flange.
"...some assembly required, ages 8 and up...... well that took longer than expected......
