Thread: Wheel alignment
Old 06-24-2010, 01:06 PM
07cob's Avatar
07cob 07cob is offline
Merv
I currently have about 1.75 degrees of camber on the front with 3.5 degrees of caster. Toe in is around 1mm.
The rears have no toe in and very little camber - say 0.25-0.5 degrees.
I am not sure of the exact settings but this was a general set up done for the road. Would be different if you want to get some benefit on the track - mostly more camber front and back.
Do you fitted a rear camber kit to the R32 back end? Without it I was restricted to no less than 2.5 degrees of camber. Now I have all adjustment necessary.
Geof
