Old 07-14-2010, 07:00 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
If you are referring to the rubber donut style vibration damper, consider its location in regards to your headers. You might melt it…Maybe finding the source of the vibration would be a better exercise.
Wheel balance is a common problem. I found that balancing my tires (I used the Road Force Balancing system) at the same tire pressure that I actually run the tires at rather than at the normal 32 psi made a huge difference. I put new tires on 2 weeks ago and they are smooth as glass on the road - first attempt at balancing.
SPFWiringDiagrams@Comcast.net
