Old 07-15-2010, 04:41 PM
Automan Automan is offline
Thanks guys
DCdoug, what do you mean by corner weights.
Dont worry, i will not be continuing with my speed tests untill i get those items looked at. Everything runs awsome up to 70 miles hour so there wasnt any signal of a problem.
Next steps:
Alignment
Tire balance
New Bracket for the steering wheel.
I will also take a closer look at this countermeasure that i did for the rubbing on the left side coil over.
So its normal for the car to lift at 100miles an hour. your right about it getting loose at that speed. it was scary. How did they manage to get higher speeds? would a front sway bar help?
