Old 07-17-2010, 10:08 AM
blykins blykins is offline
Default B2 Motorsports 347SBF Short Blocks/Complete Engines
Short Block:
*Fully CNC machined production block
*Block clearanced for stroker crankshaft
*ARP main studs
*Scat 9000 series crankshaft
*Scat forged I-beam rods
*Probe forged pistons (flat top or dish to match your application)
*Clevite main/rod/cam bearings
*Total Seal piston rings
*Felpro rear main seal
*New cam retainer plate
*ARP cam retainer plate bolts
*Comp Cams hydraulic roller camshaft (custom picked to perfectly match your application)
*Ford Racing timing chain set
*ARP camshaft bolt
*Professional Products harmonic balancer
*ARP balancer bolt
*RAM billet steel SFI flywheel
*Rotating assembly balanced
*Camshaft degreed
*Block painted, freeze plugs/galley plugs installed
*Assembly pictures provided along with build specs (bearing/engine clearances, cam specs)
$3349
*Forged crankshaft, main girdle, etc. available as options.
Complete Engine
*ARP main studs
*Scat 4340 forged crankshaft
*ARP camshaft bolt
*ARP balancer bolt
*Camshaft degreed
*Ford Racing hydraulic roller lifters
*Ford Racing lifter spider
*Stainless steel bolt kit
*Melling HV oil pump
*ARP pump driveshaft
*ARP oil pump/pickup bolts
*ARP head bolts
*ARP flywheel bolts
*Comp Cams pushrods
*Felpro gaskets
*Comp Cams roller rocker arms
*Edelbrock Victor Jr intake
*AFR 185cc heads
*Edelbrock water pump
*Moroso T-sump oil pan, dipstick, pickup (other applications may be substituted)
*CVR gear reduction starter
*Quick Fuel Q-750 carburetor
*MSD Pro Billet distributor
*MSD plug wires
*Engine broken in and dyno tested
*Build pictures, spec sheet, dyno results, and dyno video included
347ci, 450hp/425lb-ft
$8799
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
