Old 07-18-2010, 08:16 AM
Barry_R Barry_R is offline
Lots of ways to handle that area.
Remember that Ford went to breathers in the valve covers many years ago for a reason - vapors and moisture travel and accumulate at the highest point in the engine. That would be the valve covers.
Every engine needs some way to vent gases. A PCV reduces leakage tendencies and is a nice addition on a show engine. Race engines don't like the potential for oil mist introduction into the A/F mixture.
We've used PCVs back there - they work OK but are better in the valve cover. If you choose to run a PCV remember you need a way to get clean air INTO the crankcase as well.
We've run a welded up little K&N style element on top of a breather basket which works well and is unobtrusive when cosmetics are important.
We've run the factory style tall breather casting - a readily available Blue Thunder part which has been pictured. It also works OK, but can interfere with certain vehicle firewall/air pan/air filter combinations.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
