Old 07-21-2010, 05:16 AM
dlotz dlotz is offline
Originally Posted by VintageUpgrades View Post
There should be markings on the bottom of the bulb sockets E is Earth, 1 is brake/turn, 2 is park.
Mitch
You say turn/brake as of is one wore in the same. I have three wires at each tail light.
1 brake wire from my fuse box (+12) to brake switch then split to both tail lights
1 running light wore split to both tail lights
1 turn signal at each light
These 3 wires come from the fuse pannel on my American autowire 15 circuit wiring harness.
Grounds I was going to wire straight to the chassis at each light.
Do I have something wrong?
The reason I went with the (2x) 3 prong sockets was so that I could have my brake lit up on one bulb while my turn signal was on at the other. (so bothh can operate at the same time)
