Old 07-23-2010, 05:11 PM
Pman1961 Pman1961 is offline
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
Default Clutch recommendation for 408w tko 600
Okay guys..you've been extremely helpfull in my previous post. Now, I need a clutch pressure plate recommendation. I have a Superformance that will get the engine tranny swap as soon as all the parts I've order come in. Engine 408w approx. 550hp and a little less torque. I'm replacing the tko 500 with a 4617 tko 600 with .82 overdrive. I plan on using the stock bellhousing with the hydraulic clutch setup. I'm not reving to the moon nor will I be banging gears. Anyhow, I would like to have a clutch setup with a stock or light pedal feel yet be able to handle the motor in a 2500 lb car. Tell me what you've got and if you are pleased or disappointed. Thanks much!
