Old 07-27-2010, 07:24 AM
mpanten mpanten is offline
Cobra Make, Engine: SPF #298 427 FI
you can get it from Forte just make sure you tell him exactly what you have including the type of clutch, clutch fork, bellhousing, and transmission you are running. I had a heck of a time getting mine to work. No ones fault really just bad luck. Get the push system not the pull type. Also make sure you have the correct size master cylinder. Not sure if you need to change the clutch pedals on a classic roadster but most likely you will.
