Old 08-04-2010, 06:34 AM
jhv48 jhv48 is offline
If the input shaft on the TKO 600 is too long, what symptoms will the trans exhibit? Hard shifting? Grinding?
Will I still be able to bolt the trans and bellhousing completely to the engine if the input shaft is too long?
Will it eat up pilot bushings or just bottom out against the crank?
What should the clearance be between the engine and the input shaft after installation?
Jim
