Old 08-16-2010, 06:28 AM
Doubledip's Avatar
Doubledip Doubledip is offline
Send a message via ICQ to Doubledip
Originally Posted by Zedn View Post
If i can get the GTS tune, should produce an easy 325kw ATFW in stock form. The motor has everything except throttle body and includes the clutch.
Another step closer!!
Just be careful when buying a throttle body.
IF you get a factory throttle body the colour of the blade will determine the ECU you will need to run.
Silver means early (2006,2007,2008)
Brass means late (2009,2010)
www.ultimateconversionwiring.com.au
_
