Old 08-17-2010, 05:04 PM
Mike.S Mike.S is offline
Default Pin Drive Problem on Contemporary
Hello; The pin Drive "Hubs" I purchased some years ago from George P, they are the Gold Anodized set. The Rear ones mounted in the Aftermarket watts linkage / Bearing Carriers perfectly. The Front ones I bolted on a set of XKE MK3 Vented Brembo Rotors and installed on the Jag XKE Uprights, the problem is when I install the rim onto the Pin Drive "Pins"...it goes on as it should but the Wingnut only threads on a thread or two ( Fronts only). The obvious solution is that the Trigo rims that were destined for use on a Contemporary Cobra were machined with a specific backspace ...that is the magic question. Any advice greatly appreciated, Thank youName:  Pin Drive 001.jpg
Size:  37.6 KB, Name:  Pin Drive 002.jpg
