Old 08-17-2010, 10:07 PM
Wazza's Avatar
Wazza Wazza is offline
That gumball look good. Is the steering wheel on a pivot for access? Seems flat in orientation?
Hi Merv,
Optical illusion ...It's sitting loose on the console...still fitting the steering column.
But I have realized that I might need a quick release fitted on the steering wheel.....the bottom of the seat is quite long and makes it a bit tight to bend ya leg as you get in.
It really makes a difference to have a seat that fully supports the back of your thighs , rather than the usual cut off type .....but then you've got to get in and out of the car without requiring an additional joint in your legs.
I'll invent something as we go....just like a dozen other little things you don't realize when it's scribbled out on paper.
All good fun.
Warren
