Thread: Ford EECs
Old 08-23-2010, 07:22 AM
cobrarkc's Avatar
cobrarkc cobrarkc is offline
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Originally Posted by sideshow View Post
That's y so many go the ls1 route
Many many tuning possibilities
No one really bothers with ford ecus
We want to get the factory ford flash module
By y bother
I recon it be better to fit an ls1 reflector
To a ford motor them wire up ls1 ecu to a ford motor
Then tune it properly
Best thing u can do to a ford
A delco and Delphi ecu will **** many things out there
That is being a little short sighted. There are also many option for tuning the Ford EEC. you can use a TwEECer or Moates Quarter horse to tune just to mention a couple. You don't have to use their(massflo) chip. You can also load the tune from their chip into either of these tuners. Once you have it loaded you can infinately fine tune your engine to squeeze max power out of it.
Cobrarich
