Thread: Heads up!
Old 08-28-2010, 04:40 AM
BlueRooster's Avatar
BlueRooster BlueRooster is offline
Cobra Make, Engine: SPF #623 460/4x2
Default Heads up!
On 623 I broke a rear end mount on the passenger side, which in turn sheared the back mount bolt. I was very lucky the whole thing didn't snap honestly. It could have been a nightmare.
I noticed a bit of chatter in the drivetrain when taking off in 1st. I thought it was the original motor mounts, so I changed them to the SCOF polys. It helped, but the chatter was still there. If you experience this noise, check the whole drivetrain, not just the motor or tranny mounts.
The passenger side mount was completely ripped off. So a stronger one was welded directly to the frame and with much thicker flat bar. Also, on some of the earlier cars the back mount, the one with the bolt running through it sometimes has the bracket collar resting on the bolt threads which creates a weak spot and can shear the bolt. That is exactly what happened to me.
There is no complaint here, just a heads up. I drive this car constantly. I have almost 20,000 miles on it and I do not baby it in any way.
I know that I don't post that much anymore, but I hope everyone is doing well.
Dane
