Old 09-06-2010, 06:17 PM
mbeers6 mbeers6 is offline
Cobra Make, Engine: B&B,351w
Default Electric Fan Radiator Mount?
Hello all,
Well I sprung a leak in one of the fins on my stock B&B radiator. I believe the radiator is from a 1978 Ford MUstang II given the mounting brackets etc.
The leak occurred because the electric pull fan was mounted to the radiator using the 4 zip ties. When I replace or recor the radiator I want to mount it to the sides of the radiator, but I'm not sure which universal kit to use.
THere are ones from summit, etc. Can anyone recommend a mounting system for a 16" fan which will require THE LEAST amount of fabrication? I assume I will need to have the brackets welded to the outside of the radiator.
http://www.summitracing.com/parts/SUM-329725/?rtype=10
Any thoughts? I found this one from Speedway which looks like it would work
http://www.speedwaymotors.com/Univer...Kit,24857.html
