Old 09-15-2010, 07:16 AM
cobrarkc's Avatar
cobrarkc cobrarkc is offline
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Originally Posted by Jim Kellogg View Post
Doug,
When I upgraded to the Beaumont unit, I also went from AN10 to AN12 lines for more flow, and changed the oil cooler to AN12.
for you.
Jim Kellogg
Breesport, NY
If the port coming out and into your engine is 1/2"npt that is -10an sized. How will going to -12an give you more flow? It is only going to give you a pressure drop. This is basic plumbing, if you have a 1/2' feed in you house and feed your shower with 3/4" the pressure drops can flow more than the smallest point. I don't think anyone has 3/4" oil ports on these engines, especially internally.
Cobrarich
