Old 09-23-2010, 04:32 AM
sideshow sideshow is offline
i got put down on the lexus forums for writing something bout megasquirt
here is the deal
if u have alot of time and u kno whow to diagnose stuff then build yrself a megasquirt
read the forums spend days even weeks researching it
then build it and make sure u solder properly
or buy prebuilt one
now wire it up and sort the niggly probs
if u dont have time or not to good on diagnosing then buy a microtech
megasquirt is a build yr own and tune yr own ecu
so if u understand that by all means buy one
i run a shop and if i told a cusotmer its 1000 dollars to build and wire a megasquirt
thats ok then i wil say it migh tbe another 1000 bucks to get it running thats what kills it
me as a shop cannot afford somehting i cannot give warranty on
if i buy an ecu form someone else and if fails i send it right back
if negasquirt fails then i have to resolder all the stuff or see where i fkt up
anyway its a good ecu no diff to microtech i guess but u have to sort the problems out yrself
so y would i bother when i can buy somehting for bit more wire it and it will start first go
then i say here take it to tuners i get paid see ya later
its aimed at backyarders thats y its so popular only on forums
anyway justin has done a****load of research and testing and he has gotten an ls1 ecu to run on a vs 5lt v8 with a dizzy and single coil and spark plug leads and dizzy cap
so u dont need 8 coils
so basically we can set this up on most of ford or holden v8s
and most of the times it wont break the bank
so any v8 with a dizzy
and a tps most tps are 0 to 5 volts
coolant temp sensor piss easy to fit
idle motor needs holdenb 4 wire but can leave out if too hard to fit
we r working on an easy fittment of these
single coil can be anyhting but need to use ignitor too
but we have found if we use an ls1 coil just one
it has inbuilt ignitor so few less wiring and parts to work with
anyway the ls1 shots on nealry evry ecu out there when it comes to ease of tuning
and amount of tuners out there
sorry cant give out too much info as i dont htink anyone has done it locally
so if anyone is interested please send us an email
we can fit it to yr motor complete driv ein drive out
we can also sort out fitment to old carby v8 as we can do manifold setups too with fitment of injectors and fuel rails etc etc
my website
www.sideshowsperformancewiring.com.au
