Old 09-28-2010, 07:40 AM
fredd14 fredd14 is offline
Default Diagrams
DV,
Thanks,
I am removing the steering column. May repair or replace it. Also was wondering about the assembly manual as it has the wiring diagrams. If I replace the column, I will move the accessory switch and ignition switch to the dash. Most likely a push button start switch. I can trace out pin connections for the ignition, turn signals etc, but it will be time consuming. Diagram would help. My car is highly modified and could care less about trying to duplicate the original.
Thanks
Fred
