Not that I went thru the same process as you, but I can tell you that there are private inspection stations that can test with the probe up the tail pipe. You have to call around - I can give you the name of the place I used in Princeton if it helps. But they will only change the emissions test date with an exemption letter that they can copy.
Ray
