Old 10-12-2010, 11:25 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
What would you do about exhaust? would you be forced to run catalytic converters? I assume so. I bet the engine will fit, but the wiring, sensors, exhaust, oil filter, mass air tube and sensor, radiator hoses, and fuel lines and fuel pump will be a mess. Not to mention that you will need a custom trans mount, driveshaft, and most likely need to raise the trans tunnel 1-2 inches.
