Old 10-17-2010, 12:34 AM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
Originally Posted by cobrakiwi View Post
Make sure you know how much oil comes out, when you do find out how much it needs install new oil and mark the dip stick, make sure you add oil for the filter and cooler if you have one.
Oil has already been drained. I flushed out the system when the push rod broke to make sure there were no small pieces of metal in the system. (Did find a coupe of small pieces up on the head.) So now I am starting with a dry oil pan.... If I start on the high end, say 9 quarts, how will I know the oil level is too high? What symptoms should I look for? I will do some internet searching, but figured I should go ahead and ask here as well.
"Freedom is only an illusion when the government has all the guns."
