Old 11-08-2010, 03:45 PM
mbeers6 mbeers6 is offline
Cobra Make, Engine: B&B,351w
Originally Posted by Jerry Clayton View Post
do not use teflon tape on brake or fuel lines---they seal by flares, not pipe threads and what you have done is get some tape particals into the system
Thanks for the help Jerry. What is the best way to remove the tape already inside the system?
My thoughts:
-Remove all fittings, clean threads, use dental pick to clean female end of threads
-Mighty Vac system all over again?
-Invest in pressure bleeding sytem which forces fluid from master cylinder out to calipers?
