Old 11-08-2010, 04:15 PM
Cobra Make, Engine: B&B,351w
Default Help! Bubbles in master cylinder (1 reservoir only)
Hello all,
I've been struggling with a spongy brake peddle in my cobra and can't find the cause. This is a non power assisted brake setup, dual reservoir, Frenco master Cyliner (autozone) B&B kit car wth about 3k miles.
My first master cylinder held pressure fine, good firm peddle, but leaked at the lid. I replaced it with a new (not remanufactured) Fenco master cyliner.
-Bench bled until no bubbles.
-Installed in vehicle with teflon tape at brake line fittings
-blead brakes using helper and they felt ok.
-test drove and pedal went to the floor.
I tried to rebleed the brakes using vacuum pump, got some bubbles out, but still very mushy pedal.
I noticed with the cap off the master cyliner that as soon as I push the pedal down the small reservoir (rear brakes) burps up fluid in a small stream. The larger reservoir has no bubbles. Does this mean the air leak is confined to the rear brakes?
I know there is way to narrow down where the leak is coming from by putting a clamp on the rubber hose at each caliper. Can someone explain the steps?
My next thought is to take out the speed bleeders currently in the calipers, replaced with normal bleeders with teflon tape. Then maybe gravity blead the system.
Any other ideas? Bleeders are at top of the caliper, and I tried tapping the calipers to release air bubbles.
Old 11-08-2010, 04:23 PM
Jerry Clayton's Avatar
do not use teflon tape on brake or fuel lines---they seal by flares, not pipe threads and what you have done is get some tape particals into the system
Old 11-08-2010, 04:45 PM
Thanks for the help Jerry. What is the best way to remove the tape already inside the system?
My thoughts:
-Remove all fittings, clean threads, use dental pick to clean female end of threads
-Mighty Vac system all over again?
-Invest in pressure bleeding sytem which forces fluid from master cylinder out to calipers?
