Old 11-11-2010, 04:36 PM
Barry_R Barry_R is offline
How old is the engine? Has it always burned oil or did it start slowly and get worse? Or did it happen all of a sudden? A leakdown or compression test will not address or identify worn or broken/failed second or oil rings. Bad guides or seals will defintely cause oil use - you are using a LOT if it goes through a quart that fast....
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
