Old 11-27-2010, 05:48 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Careful
The largest compressor motor you can run from 110v is 2HP (That is true 2hp not the ones that cheat on ratings)
A 2hp compressor will produce about 8cfm at 100-125 psi. That will power smaller air tools and a small detail HVLP gun. But it will run out of air if you try to use a sand blast cabinet, large HVLP gun or typical body tools/sanders.
Be careful what you are buying. The air compressor industry is full of snake oil. If you buy too small a compressor, it will run too much, overheat and die an early death.
The laws of physics dictate how much horsepower you can get out of a 110v socket. Don't let some slick salesman or website convince you otherwise
Paul
www.65shlb.com
www.prdcrrct.com
