Old 12-12-2010, 08:38 PM
Outwest34au's Avatar
Outwest34au Outwest34au is offline
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
But if you rebore it larger, where are you going to source the larger piston from?
Valid point there.
If the toyota one takes your fancy and you only need that little extra have a look for 19 mm toyota cylinders. Nissan has a few 19mm also.
I found the wilwood not the cheapest but OK priced and came with different reservoirs and bits, but, the best bit is the ease of bleeding. All I did was fill the system and let it sit a while, then ran a 6 inch tube from the bleeder on the front of the M/cyl back into its own res. 5 minute job and no crawling around underneath.
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
