Old 12-14-2010, 05:54 PM
SP01715's Avatar
SP01715 SP01715 is offline
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
Originally Posted by Eric 1151 View Post
I used to have the same problem with my SPF. I wasn't starving for fuel, the heat under the hood was boiling the fuel in my carb when I shutoff and flooded the engine through the vents. If I held the throttle open and cranked, it would eventually start with a big cloud of black smoke. Now, at least 25 seconds before I shutoff the engine, I turn off my electric fuel pump and drain the carb by letting it idle. I also installed an Edelbrock carb insulating gasket. With my 557, I don't have enough hood clearance to use a wood spacer. No more problem. Worth a try.
Eric 1151
This is your answer. My car does the same thing. I just put the pedal down to give it more air and it fires right up.
