Old 12-17-2010, 08:00 PM
Three Peaks Three Peaks is offline
Originally Posted by David Kirkham View Post
Differential with axle housings and bearings.
This differential case had the inner pinion bore machined over sized. If you want to bore it out and sleeve it you can save a very expensive case. The differential unit is a 19 spline Auburn. The axle housings are copies of the original with the taper roller bearings. You will have to clean or replace the bearings.
Differential case $2000
Side axle housing with bearings $300 x 2 for $600
Auburn Differential $300
Retail $2900
Today $750
David,
Does this differential come with Pinion shaft, seals, pinion gear/ring gears? If not, which gears does it take- Dana 44? What rear cover would be needed for this case?
Thanks,
Bob
