Old 01-09-2011, 07:09 PM
blykins blykins is offline
I'm not talking about chirping the tires on an upshift, I'm talking about wide open, foot through the firewall in 3rd and 4th gear.....
The answer is, no.....
Once you get these cars out of 2nd or the bottom of 3rd gear and you're really moving down the road, you catch traction and your clutch is dealing with everything your engine is putting down to the ground.
The only time you under-clutch a system is if you have a weak gearbox like a T5 and you don't want to scatter the thing all over the road.
Otherwise, you put enough clutch in the car to hold the engine. None of us have cars that will not hook up in 4th gear or 5th gear....why pick a clutch that will slip?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
