Old 01-13-2011, 09:37 PM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
I also purchased HIDs and they are a great upgrade. I ended up going with one that uses a mirror to switch from hi/low. Both use the same HID bulb so there is no warm up issue when switching, amps stay steady and not an issue. I went with 6000K, they seem to put the most light on the road. They are great for dark back roads and in city highway driving. I got mine here: http://www.shopxenon.com/vi_60.htm
I also upgraded my tail lights to the 1.8" cluster from customdynamics. I purchased 4 clusters and changed the turn signal only lens into brake and turn signal setup (it required a 1157 socket from BDR). This allows me to have four brake lights light up. I plan on installing a LED strip discretely on the roll bar. I like the idea of a LED bar in a dark area under the car but think something up high will get more attention of the SUVs that sit high up. I also plan on installing a fast blinking relay that will flash the LED a number of times before going steady. Something like one of these: http://www.customdynamics.com/signal..._modulator.htm
