Old 01-16-2011, 09:38 PM
Keithc8 Keithc8 is offline
Smile Best Buy on a Kirkham in a long time.
I have my Kirkham number 629 for sale. It has about 250 tuned in miles on it and has always been kelp in my heated and cooled garage at my house. Dave did this car for me with about all options but does not have the stainless frame, drop foot box or the larger tank. Pretty much loaded from there.
Polished with the brushed stripes and stainless steel side pipes. All aluminum Pond side oiler block with 482C.I., 4340 steel crank, 4340 steel rods, Diamond pistons, street solid roller, T&D shaft rockers with ported Pond 427 MR SK aluminum heads, Edelbrock Performer RPM intake. Quicktime bell housing with TKO 600 transmission. All of the Kirkham goodies such as their special clutch linkage and aluminum fork set up, Surge tank, powder coated behind the seats, drivers seat tracks, driver and passenger ventalation, All billet suspension with their pulleys, brackets, oil cooler and lines with remote oil filter mount.
Our installation is second to none after doing about 20 of these cars we have it down pretty well. All wiring covered with same covering that Kirkham uses with the correct and nice routing of everything. Has the turkey pan and all. The wheel alignment has been done and the car drives and runs great. Has new Goodyear billboards on the carounted and balanced. The car has been lowered for that correct stants.
The engine made 630HP and about 619 ft/lbs of torque. this is the best running 482C.I. engine that I have had in one of the3se cars. The engine idles at 700 rpms, cranks easy and you can cruise the car at 2000 rpms no problems. You can pull this engine done to 1500rpms and it will pull right out of it with no problem. One of the best driving and cruising Kirkhams that you will find and as you would suspect very fast when needed.
Already driven the car to a couple of shows about 80 miles round trip and the car ran great, cool and won both shows. This is a worked out car that comes with a new MSO with your name on it from the Kirkham's. We can get you an Arkansas title with your name on it for about 5000.00 that would say 1965 Kirkham Roadster. Everything on the car is either aluminum, polished or black. No of color parts or blue and red lines. this is a top notch build that Keith Craft and Kirkham stand behind. Not like buying from an individual and having an engine problem and they are like o well. we all know that the Kirkham's stand behind their product.
Car was sold for 105,000.00 and customer sent a depsosit but never came through with the rest after working with him for over three months. Now he will not respond to calls or e-mails. So now you can get the car for what is owed on it at 98,000.00. He has made the down payment for you so you save that much.
Have the car now and get it all ready for the drives and shows coming up in a few months. The roller alone was over 76,000.00 from Kirkham so you do the math on what it took to buuld the car with parts that we have used,
If serious call Keith at 870-246-7460, you can also see pictures of the car at www.keithcraft.com, in the for sale section.
Thanks, Keith Craft
Keith C
